1. gcopping
  4. Friday, 17 February 2023
https://addinghambowlingclub.com/
Hi JohnO,
If you look at the link above the rotating competition photos use J51_LayerSlideShow. It works fine on most devices but on the smaller smartphone devices it displays all the images in a line thus overflowing the display past the righthand side.
Can anything be done about this?
Regards,
Gary
My user has said I can remove those photos (as they were old anyway) so that removes the problem. So unless you want to find out what was causing the problem then no need to follow up.
Thanks,
Gary
Hi Gary
Just to confirm that this is a module related issue, could you try enabling one of the default Joomla templates (Protostar / Cassiopeia) and see if the issue still exists?
Yes it worked fine in Protostar so not sure where this leaves us - any ideas? Or perhaps I just need to change how I present these photos.
Regards,
Gary
  3. # 3
