1. gcopping
  4. Wednesday, 13 January 2021
http://www.addinghamcivicsociety.org.uk/
Please check the bottom of this page where I have added a slideshow. I have set the Max Height = 200 which is the actual size of the images I am displaying, but on my laptop the pictures displayed appear so much larger than that asked for, so that they are cut off and also overlap the footer. I am using your template J51_Jasmine in the module position bottom_1a. On my smartphone the full image shows but still overlaps the footer.
I do have another J51_LayerSlideshow in showcase_1a position on this page - is this affecting it?
Can you please help?
Thanks,
Gary
Hi Gary
To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS). This should make it slideshow in the bottom-1 position better suited to your needs....
.bottom-1 .layerslideshow .owl-item img {
width: auto;
min-width: auto;
.bottom-1 .layerslideshow .info.wrapper960 {
position: relative !important;
.bottom-1 .layerslideshow {
max-height: none !important;
Ciaran,
Great thanks for this which has worked fine. However I have just noticed that on my smartphone the Slide Title and Caption do not appear, is there a parameter I need to change to get them to appear?
Regards,
Gary
Ciaran,
Please forget this as I have now realised how to do it. Thanks for your help.
Regards,
Gary
