1. Welker
  3. Monday, 04 April 2022
Hi, on template Riley there are under the J51_LayerSlideshow arrows on the left, shown in a box ... how to remove the box around the arrows or/and the arrows?
We seem to be having trouble replicating this boxing of the LayerSlideshow arrows. Would you have a URL to an example of this issue?
Hi Ciarian,
thank you for the fast response!
here the link
http://www.hofstettentreffen.de/2023/
boxes around the arrows i have just changed:
in template.css by setting webkit-appearance to "none" ... former "button"
button,[type=button],[type=reset],[type=submit]{-webkit-appearance:none}
button:not(:disabled),[type=button]:not(:disabled),[type=reset]:not(:disabled),
Thank you for the update and for sharing your solution. We have applied this fix to both the module and the template override which will be available with the nex template update.
