1. gcopping
  4. Thursday, 13 January 2022
Ciaran,
I seem to have a lot of questions at the moment!!
I have set up a Slideshow but whatever module position I display it in the image is expanded much larger than it's actual size and the bottom part of the image gets truncated. The image size is 120x160 and I have set the maximum height to be 160 px. Any ideas why this isn't presenting correctly?
Thanks,
Gary
Hi Gary
Here is the URL:
http://www.finefencingburley.co.uk/
Look to the bottom of the page - the module is in contentbottom-a.
Thanks,
Gary
Thank you Gary
Does the following Custom CSS give you the desired results?
#container_showcase1_modules > .wrapper960 {
    max-width: 1180px;
  3. # 3
No it didn't make any difference. I also tried changing #container_showcase1_modules to #container_contentbottom-a_modules as that is where the module is displayed, but this didn't make any difference either.
However I have rejigged the site to accomplish what my client wants without using this, so although it is frustrating that I couldn't get it to work it is not now at all critical to fix.
Best regards,
Gary
  3. # 4
