1. webknecht
  4. Thursday, 27 April 2017
just recognized, that there is a big problem with the J51 Layer Slideshow Modul under Joomla 3.7.0!!!
I am unable to change the pictures in the settings!!!
please check
Thank you in andvance
Juergen
Hi Juergen
This issue has been amended (Joomla 3.7 related). To resolve re-download your template from your Joomla51 'My Downloads' and install the J51 LayerSlideshow module from your download via your Extensions Manager. No module settings will be lost.
I used the modul from the J51 Ashley package i bought last year, but now I have no access to this new version.
Is ist possible, that you can give me temporarely access for this template.
To buy it again would also be no problem.
Juergen
just made the 3 months subscription and downloaded the Ashley Template.
Using the new Module all works fine, but all settings seems to be gone, after installation.
Is there a trick to save settings??
Juergen
Hi Juergen
Thank you for your subscription.
Thank you Juergen
There was indeed an issue with the LayerSlideshow and Joomla 3.7 which we have just resolved. We have updated your module via the access details provided and it is now working correctly. You can obtain this updated version of your template/modules via your Joomla51 'My Downloads'.
now it works fine concerning new pictures and items but the settings of the old version like captions, url to pictures, etc are completely gone!!
I tried it with my backup installing the new modul over the existing.
Juergen
