MENU
  1. vincebodie
  4. Thursday, 22 December 2022
Suddenly the main slideshow on one of my sites is not working properly. It is not rotating images any longer but is stacking them vertically instead:
https://experienceglass.com/
Some of my other sites where the module renders correctly are using v1.1.10 of the module (included with the Nadia template for example). The above site is using v1.1.6. Perhaps I just need to update the module, however I can't find a download for it separately.
I've done this some days now, any progress? Hope so!
Vince
Any luck with this? Please let me know ASAP, thanks.
Hi Vince
It appears the jQuery Easy plugin was disabling jQuery from your site. As the LayerSlideshow module requires jQuery, I have re-enabled jQUery and your slideshow is now loading correctly.
Hi Vince
Thanks for doing that but I'm still not seeing the text blocks over each image. Can you have another look? I can't figure it out.
Hi Vince
Have you since resolved this issue as your homepage slideshow appears to be now displaying text?
Yes it is now and I'm not sure what fixed it... ;)
