MENU
  1. ecweb
  4. Friday, 21 September 2018
I am trying to resize the slideout column for mobile view down from 256px wide (default) to 150px.
I have found the css where I can resize the size of the slideout, however the body_panel div is dynamically moved 256px to the right when a user clicks to bring up the sidecolumn menu.
How do I change the body_panel div code which is dynamically added as transform: translateX(256px); - to instead be transform: translateX(150px);?
The web site I am working on is http://essendonbwc.org.au
brilliant :)
Firstly add the following to the Custom CSS field of your template settings...
.slideout-menu {
    width: 150px;
.slideout-open .slideout-toggle {
    right: 150px;
Next, open your templates scripts.php (../templates/j51_kodaline/inc/scripts.php) and replace the 256 on line 32 with 150.
That should do it.
