1. SYSOPONLINE
  4. Monday, 06 April 2020
I have a problem with the J51_Kinvara template. We use this on the website http://www.tappzeit.de. If you visit this website on your mobile phone you can't click on menu items like MTGO Friday. allowParentLinks: true is already set and I copied the content jquery.slicknav.js to jquery.slicknav.min.js. When I select slicknav in the template settings the menu is not visible.
  1. http://www.tappzeit.de
Thank you Thomas
You appear to be loading your your own version of jQuery. If required may I suggest using an extension like jQuery Easy (https://extensions.joomla.org/extension/jquery-easy/).
Joomla can be particular about how and what version of jQuery is loaded.
