1. albo1
  4. Monday, 25 April 2022
I also have the FontAwesome issue after upgrading to J51_Kaylee_J4. Unfotunately the "Hamburger Icon" at mobile Menu which is also FontAwesome ist not working properly. Instead of the 3 Bars an rectangle occured.
Do you have any idea to change it correctly?
Thanks in advance.
Fred
Problem solved
Hi Fred
Thank you for reporting this issue. We have just released an update for the Kaylee template, to resolve the issue could you try updating your template to this latest update. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
many thanks for the Kaylee update, FontAwesome works now perfectly. But I have figured out that another Problem exists. The mobile Menu didn´t work with any header Image (Template Style->General->Header Image)
As long you leave it blank, without any Image, everything is fine and the hamburger menu opens straight up and shows the whole menustructure.
Thanks in advance
Hi Fred
Thank you for bringing this to our attention. We have just released an update which should resolve this issue (v 1.0.4).
thank you for the new update to v 1.0.4. But the Mobile Menu is still not working. it´s the same thing. Without using the Option "Header Image" an leave it blank the Hamburger Menu is perfectly working.
Thank you again in advance
Hi Fred
Thank you Fred
Strangely we are unable to replicate the issue regarding your mobile menu. We have tested on both Chrome and Firefox and the mobile menu toggle icon is displaying without issue. Could I ask you to try a full refresh (clearing cache etc.) and see if this resovles the issue for you?
Regarding the menu item indicator icon, we have created an update to the template to resolve this issue. I have installed this update to your Joomla installation.
thanks for the quick response.
Firefox and Chrome without problems, but unfortunately not in the Safari browser (Iphone) or the MS Edge browser.
Kaylee on Joomla 3 has no problems at all.
The J5Thumbsgallery doesn't work either.
Many Thanks in advance
Fred
Hi Fred
Unfortunately, we are still no longer able to replicate this issue. We have tested iPad Pro 12.9 2021 v14.5 and the menu is functioniung without any problems. Similar on MS Edge (101.0.1210.47).
Ensure that all application is cleared before retesting (MS Edge -> Dev tools -> Application -> Storage -> Clear site data).
Hi Fred
Regarding your ThumbsGallery issue, try adding the following to the Custom CSS field of your template settings...
.visible {
opacity: 1 !important;
