1. gcopping
  4. Monday, 10 May 2021
Ciaran,
I already have 20 module overrides in the Jasmine template. When I select the + to add a 21st nothing happens - can you please check this out for me?
Best regards,
Gary
Sorry, my mistake entirely as I did not realise that Module Overrides were available, but what I am having trouble with is Module Style Overrides. If you look in that account that I emailed you will find 20 Module Style Overrides, and that I cannot add a 21st.
I look forward to hearing from you.
Regards,
Gary
Thanks Ciaran your help is much appreciated as usual. All good now.
Gary
Hi Gary
Sure. Admitedly it may not be a template related issue, regardless, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Just checking that you got my email from 11 May as I didn't hear back from you yet?
Regards,
Gary
Thank you Gary
Strangely we are unable to replicate any issues. We have been able to create an override without issue...
Are you having this issue on any particular extension? If so then the issue is likely related to that extension.
Hi Gary
Thank you for detailing. By default, there is indeed a limit of 20 overrides. I have just increased this limit to 100 for your template.
