OK thanks for this which I will try. The reason I am trying PHP 8.1 is that my server host is saying that they are switching off 7.4 in early February therefore I need to move my sites to 8.1. When I switch on error reporting I get the following but then can't get into the backend to switch it off so I am stuck - any ideas how to get out of this? I also still havn't had a response to an email I sent to info@joomla51.com last Friday - is anybody monitoring these emails?
Deprecated: Joomla\Input\Input implements the Serializable interface, which is deprecated. Implement __serialize() and __unserialize() instead (or in addition, if support for old PHP versions is necessary) in /home/nepalcom/
http://joomla4.nepal-systems.co.uk/libraries/vendor/joomla/input/src/Input.php on line 41
Deprecated: Return type of Joomla\Input\Input::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/nepalcom/
http://joomla4.nepal-systems.co.uk/libraries/vendor/joomla/input/src/Input.php on line 170
Deprecated: Joomla\CMS\Input\Input implements the Serializable interface, which is deprecated. Implement __serialize() and __unserialize() instead (or in addition, if support for old PHP versions is necessary) in /home/nepalcom/
http://joomla4.nepal-systems.co.uk/libraries/src/Input/Input.php on line 31
Warning: session_name(): Session name cannot be changed after headers have already been sent in /home/nepalcom/
http://joomla4.nepal-systems.co.uk/libraries/joomla/session/handler/native.php on line 128
Deprecated: Joomla\CMS\Input\Cookie implements the Serializable interface, which is deprecated. Implement __serialize() and __unserialize() instead (or in addition, if support for old PHP versions is necessary) in /home/nepalcom/
http://joomla4.nepal-systems.co.uk/libraries/src/Input/Cookie.php on line 0
Warning: session_cache_limiter(): Session cache limiter cannot be changed after headers have already been sent in /home/nepalcom/
http://joomla4.nepal-systems.co.uk/libraries/joomla/session/handler/native.php on line 235
Error: Failed to start application: Failed to start the session because headers have already been sent by "/home/nepalcom/
http://joomla4.nepal-systems.co.uk/libraries/vendor/joomla/input/src/Input.php" at line 41.
