1. gcopping
  4. Wednesday, 23 March 2022
Still testing this template in J4 & have just noticed that the down arrows are not showing when there is a dropdown menu - please see the link below.
http://www.joomla4.nepal-systems.co.uk/
Thanks,
Gary
Hi Gary
Strangely the icon is displaying for us without issue. To amend could you try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.hornav > ul .parent-indicator {
font-weight: 900;
Sorry Ciaran that didn't work.
Regards,
Gary
Hi Gary
We have just created a new update for the Jasmine template which should hopefully resolve your issue. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
Note that if using the old Font Awesome 4 syntax, you must add the fa class to the font element. In Joomla 3 this was not needed but as Joomla 4 is loading Font Awesome 5, it will be now required.
