1. crimle
  4. Thursday, 26 May 2022
I have two issues with J51_Jasmine_J4 1.1.5.
1. The Front-End login fields
They seem to be somehow disordered. See attached screenshots. Your demo website looks quite ok, but is considerably different from my website. Maybe your demo is Joomla 3?
2. Front-End-Editing buttons
These buttons seem to be disordered as well. In some cases they are not visible at all. See attached screenshot.
The button in the top right corner opens the article in the third column underneath the leading article.
The button further below opens the leading article.
There are no buttons for editing the articles in the first and second column.
Thank you and kind regards
Chris
Attachments (3)
Hi Chris
May I ask what version of the Jasmine template have you installed? Each of these issues should be resolved with the latest version (1.1.5).
it is J51_Jasmine_J4 1.1.5 for sure.
Kind regards
Chris
Hi Chris
Thank you Chris
I have just installed a new template update to your Joomla installation which has resolved the issue regarding the row layout in com-users-login. I notice there is a slight 'issue' with the size of the password input however this appears to be coming from CSS in your custom.css (btn).
The module edit button issue appears to be already resolved (testing both CHrome and FireFox)?
Thank you Ciaran. Everything seems to be ok now. And I removed the inappropriate code from my custom.css.
Kind regards
Chris
