http://perkinsandshaw.co.uk/
On this site there is a lot of padding between the blue bar and the text and I cannot see how to reduce this. There seems to be a lot of padding between the various modules and I have set the "Remove Container Padding" option to "yes" wherever it is available - can you please help?
With the Joomlage Icons module is there a way to switch off the Link option. If I just blank the "Link To" field if defaults back to the joomlage link?
Thanks,
Gary
