1. Patricia
  3. Saturday, 03 August 2013
I can't get my images to appear. I have used the module in several places on the homepage and they work ok.
URL: http://www.brazing.nl/leonie
Module is: makeovers (position: contentbottom-a)
Could this be affected by the joomla update to 3.15? Because this problem has only occurred after the upgrade.
thanks!
Patricia
Hi Patricia
This particular module appears to be trying to load an image which does not exist or can not be accessed (http://www.brazing.nl/leonie/images/homepage_left/Francie_Before.jpg).
Of course! thanks.
I have another question however. My preference would be to have a mini slideshow there (before and after photos). If I create a slideshow module however, not only does it not appear, the slideshow at the top disappears too. Do you have a solution?
thanks!
Patricia
Hi Patricia
May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email
Thank you Patricia
The module you had published in this position was the J51_Slideshow module. I have unpublished this module and published the ImageLinkHover module you has set up and it appears to be working without issue.
That's right. I was hoping actually to have a slideshow module there, is that not possible?
Patricia
Hi Patricia
I have installed the briask slideshow for your contentbottom module position. This is a mootools slideshow which is less likely to cause any conflict with other extensions. Both slideshows appear to be now working correctly.
