1. ThomasBraun
  3. Thursday, 27 April 2017
Hi there,
are there any known issue with Jommla 3.7 and your J51 Imagehover?
The module does not work on my site after updating to J3.7 anymore.
You may have a look here: http://www.thbraun.dehttp://www.thbraun.de
The images should appear below the showcase.
Best regards,
Thomas
Thank you Thomas
Re-installing the module appears to have resolved the issue.
Great, thank you!
Mysterious, I also downloaded and installed the actual version from your site before.
Whatever, now it works again
Many thanks,
Thomas
I install modoul in new sample website soon ...
to fix problem on that smaple site.
Thanks alot for your Attention.
  3. # 3
We have tested locally and have been unable to replicate any issues on 3.7. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
  3. # 4
my j51 imagehover dont work in 3.7 version of joomla.
Please help me with it...
my web site is demo1234.ir
  3. # 5
There does not appear to be any example of the ImageHover module at the URL provided. Would you have a URL to an example of your issue?
  3. # 6
We are still unable to locate any example of the J51-ImageHover module (https://www.joomla51.com/free-module-extensions/item/j51-imagehover) on your site. Would you have a URL directly to an example of the module and your issue?
  3. # 7
my website is : http://demo1234.ir/
please check my issue
  3. # 8
