1. Drew
  4. Thursday, 16 April 2020
Good day,:D
I recently went into the icons module to update some content, and after I 'saved', it removed the html for the 'read/learn more' button.
Here is the content which previously work:
.....Now take the guesswork out of building envelope sealing and provide guaranteed results.
<form>
<input type="button" value="Learn More" onclick="window.location.href='https://www.pacificridgellc.com/envelope-sealing'" />
</form>
I've not changed any of the editors. Currently using JCE Editor, and even switched over to TinyMCE with no differance. Text filters are correct as well as the Super User having 'No Filtering'.
So - has something changed along the way to remove the previous html.
OR is there somewhere better suited for the module when using html, since there is not really an editor on screen for the module.
Thank you for your input.
- Drew
Hi Drew
To amend please try installing the attached update to the J51 Icons. This update should allow you to display raw HTML in the caption field as before.
Thank you. However now the page displays all code, as is, input into the module.
hmmm. Thoughts please.
- Drew
Hi Drew
