1. Glen
  4. Monday, 06 November 2023
I'm not able to figure out J51 Icons. I can create the modules and add an icon, but how do I associate text with the module position.
You'd think you'd be able to add the custom text right in the same module, but there is no place for it, except the description field, but no place for more formatted text. Is all that is shown in the demo formatted by markup in the description field? That is what I have used for now. https://canwood.ca/Staging2023/ 1a, b, c
How do I set up the modules as shown here:
https://www.joomla51.com/demo/0170/index.php
where the J51 icons are separated, with the page background showing around them. I have 3 separate icon modules set up with the background-color class applied, but they are all merging together as one horizontal box. Each is in a separate module position 1a, b and c. I made one grey to show the separate modules.
If there are module classes for the J51-icons, where are they listed? See attached.
Yes, Thank you Ciaran
Glen
Hi Glen
The description field of the icon module will accept HTML. Following is an example of the HTML added in the template demo...
<p style="margin-bottom: 20px;">Sed egestas, ante et vulputate volutpat, eros pede semper est.</p>
<ul class="chevron">
<li>Cras ornare tristique elit.</li>
<li>Ut aliquam sollicitudin.</li>
<li>Cras iaculis ultricies nulla.</li>
<li>Vestibulum commodo.</li>
</ul>
In the demo the J51 icons are separated, with the page background showing around them. I have 3 separate icon modules set up with the background-color class applied, but they are all merging together as one horizontal box. Each is in a separate module position 1a, b and c. I made one grey to show the separate modules.
Glen
Hi Glen
Does setting the General Settings -> Background Style option to boxed in your icons module give you the desired result?
