1. [email protected]
  3. Tuesday, 26 November 2024
I've defined the URL's for the social icons but the icons are not visible.
Where are they? Supposedly they come from Font-Awesome?
https://dev.mdmen.org/images/Screenshot%202024-11-26%20155621.png
  1. https://dev.mdmen.org/index.php
your using the wrong codes for the icons (using FA6)
twitter/X is: fa-brands fa-x-twitter not fab
Thanks for your response. I recently purchased this for a new site and don't know very much about FA. These are the default settings in the template as purchased from you.
How do I fix this? I've used the settings you provided below and they don't appear to work.
https://dev.mdmen.org/images/Screenshot%202024-11-27%20103612.png
Hi Scott
OK - login info sent.
While you are in there, please also look at:
https://www.joomla51.com/forum/j51-hayley-responsiveness
The email I sent above was returned as undeliverable.
Do you have a good email address I can use?
Could you try resending and cc in [email protected]
Do you have it yet? I sent this again two days ago and copied your gmail address.
I just sent it again directly to your gmail address.
Thank you Scott
Ciaran,
Thank you very much! :D :) :D
The tiktok icon shows an error Icon when I use "fa-brand fa-tiktok"
You can try this:
Joomla 4/5 uses fontawesome v5 so it should be fab fa-tiktok
and add
.fab::before {
font-family: "Font Awesome 5 Brands" !important;
into your custom css
I already used that code for the templae
thank you. I didn't try "fab fa-tiktok"
