1. gcopping
  4. Thursday, 02 March 2017
I have 2 questions about this template:
1. If you look at http://www.electricadjustablebedshop.com on a mobile or tablet there is a lot of space between the logo and the next part of the site. I understand that this is because the logo is resized for these devices. However is it possible to either specify another logo for these devices, or to move the rest of the page up, to remove this blank space?
2. Is there a way to reduce the top and bottom padding for the showcase module?
Thanks for your help.
Gary
Thanks Ciarán much appreciated.
Gary
Hi Gary
#container_header, .logo_container, h1.logo, h1.logo a {
height: auto;
#logo {
position: relative;
Thanks this seems to reduce the space for landscape view on mobile phones, but for portrait view there is still a large blank space below the logo - is there any way to eliminate this?
Also you didn't respond on my second point.
Additionally in the Module Widths options it is possible for some modules to Remove Container Padding but this option is not available for Content Top Module Width Settings - how would I do this?
Gary
Hi Gary
For your logo may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
To remove the padding around your contenttop modules try adding the following to the Custom CSS field of your templates parameters...
.wrapper_contenttop {
padding: 0 !important;
We have amended your custom CSS to the following which appears to have amended the issue...
#header, #container_header, .logo_container, h1.logo, h1.logo a {
height: auto;
#logo {
position: relative;
width: auto;
