1. pigos
  4. Thursday, 12 November 2015
Hi Ciaràn,
is it possible to avoid the transparency effect on the caption block on mouse hover, leaving the zoom effect on the image?
I mean, I would like to have the caption background and text fixed in the colors defined in General settings of the module.
Many thanks for your help
Hi Pigos
Would you have a URL to an example of your GridGallery?
http://www.sellaaaltolagrange.gov.it/
I would like to remove the transparency effect from caption and caption title, fixed color only for background and text, the zooming effect on the image is ok for me.
thanks
THank you
Try adding the following to the Custom CSS field of your templates parameters...
.j51gridgallery figcaption {
opacity: 1 !important;
  3. # 3
How can you completely remove the mouse-over opacity effect of the grid gallery? It doesn't make much sense in a mobile environment where you can't hover the image. I'm using the Central template.
Thanks.
  3. # 4
Would you have a URL to an example of your GridGallery module?
  3. # 5
