Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. Umadesign
  3. Sunday, 17 August 2014
I moved GridGallery to position Top-1 a, after that the pictures are not active, can not see the text. I saw other posts about that problem but it did not help me. You can see it from http://www.umadesign.ee
Thank you Kertu
I have added the following to your templates index.php, loading Modernizr which has amended the issue...
<script src="//http://cdnjs.cloudflare.com/ajax/libs/modernizr/2.8.2/modernizr.js"></script>
For some reason I can not see the change. Could You check again. GridGalleri is now bottom-1a.
Thank You,
Kertu
Hi Kertu
On hover of your image the description text is now appearing as it should. We have checked in Firefox, Chrome and IE.
I have checked in several computers and in some it works fine and in some it´s not. In some cases it is probable about the computer because if I check Your Habitat template demo its not working either. My laptop shows everything fine. PC is showing grid gallery on Habitat template demo fine but on my web page it´s still not working. Maybe the module is someway corrupted. Unfortunately I have overwritten the original module, is it possible to replace it with original so I could start over.
As this module uses CSS3 transistions please ensure that your browser is up to date and fully supports CSS3. The only way we have been able to replicate this issue is with older versions of IE and Firefox.
