1. RalfG
  3. Friday, 15 December 2017
I can not find the editor icon in the frontend.
I have full authority, but I can only change modules but no articles.
Template is up to date!!
What can i do?
  1. http://www.hofladen-ohnemus.de
Oh many thanks. Simply ... if you know it :D
Now it works!
OK, Email was sent.
Thank you Ralf
It appears the issue is present regardless of the template that is enabled which would indicate that this is not a template related issue. Have you disabled frontend edting in your article options in any way? Maybe hidden the editing icons?
Hi Ralf
My apologies, we only tested your homepage. To amend try adding the following to the Custom CSS field of your template settings...
.icons > div {
background-color: #888;
