1. ecweb
  4. Wednesday, 08 August 2018
I am trying to add 3 columns to a drop down menu and have added ' columns-3' to the main menu item (the text separator) which has the sub-items. However, only one column still appears.
What am I missing?
See the drop down menu under 'web shop' on this page: http://103.42.110.23/~peterwats/
Thank you - great work!
Your dropdown should be now displaying in 3 columns as requested.
ok - done.
Thank you for your help :)
Unfortunately, that didn't solve it.
I have added the css - you can see it at http://103.42.110.23/~peterwats/index.php/features/herbs-and-spices
Note the dropdown menu under 'web shop' is still one column
By default this option is not available with the Fedora template. To amend you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.hornav .columns-2 + ul {
-moz-column-count: 2;
-moz-column-gap: 0;
-webkit-column-count: 2;
-webkit-column-gap: 0;
column-count: 2;
column-gap: 0;
width: 420px;
.hornav .columns-3 + ul {
-moz-column-count: 3;
-moz-column-gap: 0;
-webkit-column-count: 3;
column-count: 3;
column-gap: 0;
width: 630px;
.hornav .columns-4 + ul {
-moz-column-count: 4;
-moz-column-gap: 0;
-webkit-column-count: 4;
column-count: 4;
column-gap: 0;
width: 840px;
