1. ecweb
  4. Friday, 20 May 2016
I love this template!
We have an issue though - on the smart phone version of this template, the sidecol-a and sidecol-b modules display before the content of the page.
We would like to display these modules after the content of the page.
How do we achieve this change?
#main {
display: flex;
flex-direction: column;
#sidecol_a, #sidecol_b {
order: 1;
Excellent - thanks for your help,
It seems to work well except in Androids default 'browser' app - there it appears as seen in this image: http://easyjoomla.com.au/images/androiddefaultbrowser.jpg
Can you help with this as well?
The web site is http://www.lukesantennas.com.au
I have tried an alternative sorting solution using flex which will hopefully work better for you across all devices...
#main {
display: flex;
order: 1;
Thanks for your help so far Ciaran,
Isn't that the same code we tried earlier in this post?
I have now refreshed the cache and tested using the default 'browser' app in Android and the issue remains with the contact form overlapping the footer.
Ah so it is. Had you already tried the following using the table method?...
#main {
display:table;
#content_remainder {
display: table-row-group;
float: none;
display: table-footer-group;
float: none;
Great work - that solved the issue for me.
Thanks!
Great!!... thank you for the update. :)
Hi, Im having the same issiue. In fact this did solve the problem but I have recently installed the updated template and I have seem to have the same problem. I have tried both custom CSS but I still have the sidecolum showing before the content in mobile views. my site https://freightweek.org/index.php/en/single-book/2022-issues/issue-11-2022
hope you can help me please.
