  1. GF
  4. Wednesday, 14 September 2022
Good morning Ciaran,
I'm trying to upgrade an existing J3 site with J51_Everly to a J4 version. Unfortunately without luck...
The site is working fine with Cassiopeia but not with Everly. I'm getting this warning:
'.../domains/http://joomla4test.site/public_html/components/com_content/helpers/route.php' (include_path='.:/opt/alt/php80/usr/share/pear:/opt/alt/php80/usr/share/php:/usr/share/pear:/usr/share/php')
PHP8.0, J4.2.2 and newest version of the template. Already reinstalled template, languages and more...
Can you help?
(I will make a super user account for you and send the inlog)
  1. https://joomla4test.site
Could you check the access details provided as they are giving us the following error...
Is the issue present if you disable all modules?
Excuse me for the mistake.:( Please try again to login.
It seems to be a problem with a module indeed! Now to find out which one...
After some investigation, it seems that J51_Gridgallery that I used on the J3 site was the problem.
But J51_Numbers (NL and PT., EN is OK) and J51_Icons are showing warnings. Perhaps you can take a look at that?
(for reference the J3 version of this site is still to see on silvercoastglamping.eu)
16/09:
When I did an extra 'save' of the J51_Icons modules they working fine. And the J51_Numbers module also.
So no help needed anymore. Thanks
