1. arconis
  3. Thursday, 04 December 2014
Hey Guys,
I'm using Enlighten and when the window is scrolled to the top everything looks perfect, but when I scroll down the sticky part starts to "stick" a little further down than I'd like (see below). If you could tell me how to start the sticking effect about 6 pixels higher that would be great, thanks!
At top:
http://i.imgur.com/0l467uL.jpg
Too much on top cut-off when scrolled down:
http://i.imgur.com/nNCVgGd.jpg
The sticky div stop number can be set within your templates scripts.php (../templates/j51_enlighten/php/scripts.php - line 11)...
jQuery(window).load(function(){
jQuery("#container_hornav").sticky({ topSpacing: 65 });
jQuery("#container_header").sticky({ topSpacing: -20 });
</script>
Where 65 is the menu stop distance and the -20 is the header area.
Awesome, you guys are the best!
