Hi there
I have a website with "J51 Classic" Template and Kunena Forum. Kunena has ist own editor and there is a button that allows you to insert emoticons into the text. If I click the emoticon button, the screen becomes darker but nothing elso happens. I understand that ther should appear a selection of emoticons.
It seems to be an issue with the J51 Classic Template. I tried with Protostar and there the "select emoticon" bar will display all right.
Chris
