I am using the J51 Classic Template and I am also using the module ImageLinkHover. If you visit this link:
http://oreillypavingdublin.com/cpd/index.php
you will see that the hornav doesn't display all the dropdown options under the "Services" button on the homepage as this is where the ImageLinkHover is published. When I unpublish the ImageLinkHover modules the hormav works correctly. If you click the "Contact or Services" button you will see it works when the ImageLinkHover module isn't published.
I am hoping that you can help me with this please. Thanks very much.
