Hi!
I downloaded the J51 - Clarity and i like very much to work with it. There is only one thing that is bother me. Here is my site: http://www.test.sanoberry.ro/joomla16/index.php
On home page the the area where is the slide i can't click on the sub menu buttons. They look like they are on the back of the slide. So, how can i make the menu(sub menu) to come on the top?
Thank you!
Victoria
- VictoriaSunrise
- Site Showcase
- Monday, 23 September 2013
Yes!!! It's working now! Thank you very much Ciarán!
You helped me a lot and thank you for appreciation
it's my first Joomla site.
Have a great day!
Victoria
Have a great day!
Victoria
- Site Showcase
Hi Victoria
I have made a few changes to your jQuery Easy plugin settings and everything should be now working correctly.
Nice site btw (",)
Nice site btw (",)
- Site Showcase
I'm sorry, this is the extension that i used:
http://extensions.joomla.org/extensions/photos-a-images/images/image-magnifier/11729
http://demo.virginsoft.net/index.php?option=com_content&view=article&id=45&Itemid=29
- Site Showcase
Hi Ciarán!
My plugin was still installed because i re-installed it to see if my extension could respond somehow , anyway yesterday my extension started to work, but i'm in the same situation with drop-down menu (http://www.test.sanoberry.ro/joomla16/index.php). I have this slide on another page and there is the same problem.
I use this extension:
http://extensions.joomla.org/extensions/photos-a-images/images/image-effects/23922
and in my site i use it here:
http://www.test.sanoberry.ro/joomla16/index.php/flavors-toppings/flavors
Thank you for help!
Victoria
Thank you for help!
Victoria
- Site Showcase
Hi Victoria
You appear to have had the plugin still installed. I have disabled it in your plugin manager as requested. Could you check if your extension is back working? If you could supply us with a URL to an example of your extension we will see can we get it to work with your menu.
- Site Showcase
I installed the plugin from the link you sent me, but it didn't work in the right way. It fixed the menu drop-down problem, but now my "Simple Hover" effect it's not working at all even if it's enabled.
and even after i uninstalled the JQuery Easy plugin...
That hover effect it much more important that menu issue. Can you help to put it back?
Thank you Ciarán!
Thank you Ciarán!
- Site Showcase
Your plugin is also loading jQuery. Disabling jQuery within the plugins parameters resolves the issue on the homepage however this may effect the use of the plugin on pages where the slideshow isn't present which also loads jQuery. It may be worth installing jQuery Easy (http://extensions.joomla.org/extensions/core-enhancements/performance/jquery-scripts/18327) which ensures only a single version of jQuery is loaded across your entire site.
- Site Showcase
I really need this plugin, it is possible to solve this situation in other way? :dry:
Thank you!
Thank you!
- Site Showcase
Thank you Victoria
The issues appears to have been caused by the 'Content - simplehovereffect' plugin. Disabling this plugin in your 'Plugin Manager' has resolved the issue with your dropdown menu.
- Site Showcase
- # 9
Hi Victoria
There appears to a be a Javascript conflict with your dropdown menu causing it not to function correctly. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
- Site Showcase
- # 10
