1. ntsnet
  4. Thursday, 03 October 2019
Having a lot of problems with menu assignments.
I have two menus which are assigned to modules to display in the 'hornav' area of the template.
I need one menu to display when the Home page is showing and the other menu to show when another section (and pages) are accessed.
The assignments are not working!
I can select the main menu only and assign to the appropriate pages, BUT if I assign the second menu to the pages that the main one isn't assigned to - nothing!
Any ideas why? Or can you only have the one menu in one location??
Paul
Hi Paul
OK, have actually cracked the problem! I spent some time looking at the menus and the current assignments and noting where it worked and where it didn't. In the end it came down to Home Page assignments on each of the menus. Once I had one working correctly I copied the process to the others.
In the end it was a case of getting the logic right!
Thanks for the offer of direct help, but now sorted - a steep learning curve, but one I won't forget. :D
Paul
Excellent work. And thank you for the update.
Every day is a school day :)
