Hello Joomla51 Team,
I use the template Enterprise with the J51_Carousel Template.
I activated 14 columns (all).
Then I get the following error:
Undefined offset on line /modules/mod_j51carousel/tmpl/default.php line 96 and line 99.
If I only activate the columns until 12 then everything is fine, the error only occurs if i activate the columns 13 and 14.
I hope you can help me!
- crea
- Monday, 07 December 2015
Hi Crea
Thank you! I will upload it to my webhoster an send you an email!
Thank you for your quick answer !
I have the same problem was there a fix for this. both column 13 and 14 will not work but all others works fine.
This issue so be now amended in the lasted download of the template. Simply re download the template and install the carousel module via your extensions manager to update.
I have downloaded and installed both template and module but I still have the same issues.
