1. wneill
  3. Tuesday, 20 September 2016
I am using Stockholm which utilizes J51_Carousel in the top2a position. When the width of the browser is around 400-415 pixels or so (like on an iPhone 6), there is a gap on the right side of the image. See attachment. The image is 394 pixels wide, so once the browser width is smaller than that, it adjusts accordingly, and once it is larger than about 425 or so, it shows two images.
I would like it to switch to showing two images once it hits 394 pixels. If that won't work and there has to be a gap, I would like the image to be centered so there are small gaps on either side. I have tried a few things in the template parameters under Responsive Options, Responsive CSS, Phone Portrait CSS, but I haven't had any luck. My CSS skills are a little rusty. Ideas?
We have made some small amendments to your template settings. Could you check if the issue is still present?
Ah, that makes sense! I had tried it and it didn't work. I tried removing the slogan completely and still no luck. I wondered if it was the CORE logo or the photo in the footer and tried removing those. Still no luck.
Have you tried the suggested CSS? I believe the gap is created by the slogan div pushing outside of the template wrapper, causing this issue.
I'm not sure why you are giving me CSS for the site slogan. The problem is with the J51_Carousel. Please reread my initial post and look at the attached image.
p.site-slogan {
display: inline-block;
http://downtownstudentministries.org/youth/new/
I prefer to make the changes myself rather than providing you with a login if possible. So if you have a CSS fix, please tell me here and I'll make it.
