1. current
  4. Saturday, 22 February 2020
when in mobile view (tried both android and iphone, chrome and safari, different sizes) when the screen is on the j51 carousel module (text or photo), does not scroll up or down.
could you please check:
https://oskarsapartments.com . (accommodation & reviews at the homepage)
https://casaderosa.gr/ (reviews at the homepage)
Thank you very much!!!
Problem fixed
Rita ;)
.owl-stage-outer {
pointer-events: none;
with the solution indicated above it is no longer possible for me to click on any button inserted over the slide.
Is there any way to preserve the scrolling AND the possibility to interact, primarily with click actions, with elements like buttons (as I said inserted over the slide)?
Thanks.
  3. # 3
