MENU
  1. JoomlaGirl
  4. Friday, 31 August 2018
With J51 Carousel module is there a way to force each boxed column to be the same height? Also, where can I set the background color of each boxed column, please?
thank you
Hi Kirsty
#owl-carousel646 .item {
    background-color: #ffffff;
Edit to taste.
Thank you :) That solved the issue.
Would you have a URL to an example of your carousel module?
I will send it via email as the site is not live yet.
    min-height: 640px;
Thank you that solved the height variation issues :)
What do you suggest for the other part of my question about setting the background colour for each box, please? I would like white boxes on the existing pink background.
