1. [email protected]
  3. Saturday, 23 March 2019
Can I insert J51_Carousel where I want in an article and how, I have buy J51_Caitlin in 2017 and are happy about it.
The pictures in the article should be shown as the one in the blue bar, could be set with display of 4 images on PC, 2 pictures on TAB, 1 image on mobile
Best Regards Brian
  1. https://linelillelund.dk/index.php/da/ture-pa-egen-hand-omkring-paleochora-og-paa-sydvest-kreta/slentretur-igennem-paleochora
Presuming I understand you correctly, please try the following article which details how to place any module inside an article.. https://docs.joomla.org/How_do_you_put_a_module_inside_an_article%3F
Fully has the article you referred to but can't make it work.
I have tried standing down but nothing works
{loadposition mod_j51carousel}
{load module j51_carousel paleochora}
{loadmodule mod_j51_carousel}
Don't know if there is anyone who will help with the code I need to make, the module is J51_Carousel and is called Paleochora
The first link is since it should be on and another link you can see a corresponding module outside an article
  1. https://linelillelund.dk/index.php/da/guided-ture-pa-kreta
  2. https://linelillelund.dk/index.php/da/ture-pa-egen-hand-omkring-paleochora-og-paa-sydvest-kreta/slentretur-igennem-paleochora
Rather than stating the module name, trying using the position...
{loadposition top-1a}
Note that the position field is editable. Type a name once have clicked the position dropdown and then hit enter (eg. mycarousel).
{loadposition mycarousel}
  3. # 3
