1. dautrich
  4. Wednesday, 12 July 2023
In your answer to a post in your forum, you mentioned your extension J51 CallToAction. Is there a tutorial or a description available?
Would it be possible to create an option (either for the respective module or -better- per button) to open the links in a new window?
It is pretty easy to implement it for a module by adding target="_blank" to line 57 of default.php, but it would require a better PHP programmer than me to implement a selection for each button.
Rolf
Hi Rolf
Please find attached the latest download of our Call To Action module which includes an option to open links in a new browser window.
Sorry to say at present we do not have a tutorial on this module.
Thx! I tested the new version1.0.1 of the extension. It does exactly what it is supposed to do. Will you include this version in new versions of your J4 templates?
I've played a bit with the extension, and now I know what it does. So, I don't need a tutorial anymore. Anyway, for other users, some little tutorial would be helpful. I had never taken notice of the existence of this extension, before I saw a post in your forum.
I believe it can be used by many users. One possible use case: Replace a list of external links with a more beautiful presentation.
Rolf
Hi Rolf
Yes, we will be including this version with all related templates.
Thank you for the suggestion. I believe this is the only module we dont have a tutorial for so I will be certainly looking to rectify that.
