1. topper84
  3. Saturday, 05 April 2014
Link to my website: http://ng-gymnastik.dk/
Joomla version: Joomla! 3.2.3 Stable [ Ember ] 6-March-2014 14:30 GMT
Template: J51_Calibra
I've added the following Custom css:
#header {
position: relative;
#newmodule {
height:50px;
margin:0;
padding:0;
position: absolute;
left:20px;
top:10px;
width:200px;
z-index:99;
#hornav ul a, #hornav .separator {
font-size: 14px;
.sidecol_block h3, .sidecol_block a {
color: #444444 !important;
.sidecol_block .module ul.menu a, .sidecol_block .module_menu ul.menu a, .sidecol_block .module a {
color: #666666 !important;
.sidecol_block {
.pagination a, .pagination span {
p.site-slogan {
font-size: 100%;
Issues:
1. The left sidebar has different color on mobile device and PC. Please advise on how to change the mobile color to the same as the view on PC.
2. "More Articles..." on the bottom on the frontpage. In "Main menu" I've verified that Pagination is set to "Show". Also the numbers on the three #links have dissapeared. Please advice on how to get "More Articles..." and the numbers for #links back in the bottom of my "Featured Layout" which I use as my front page.
That was it!
Thank you so much for your help!
To so try also adding the following to your Custom CSS field...
.items-more ol li {
list-style-type: decimal;
margin-left: 20px;
.items-more ol li a {
padding-left: 0;
This added the "Flere Artikler..." in the correct position.
Would it also be possible to get the default "1, 2, 3" text from the Beez3.png-screenshot I've pasted earlier?
Ok. This should do it..
Also add to your Custom CSS field...
.items-more:before {
content: "Flere Artikler...";
display: block;
font-size: 18px;
You may wish to edit this to your own taste, adding color etc.
I've now renamed the pagination file again.
I am still missing the wanted information.
The above CSS will only work correctly with the removal of the pagination.php (you can also just simply rename it to pagination1.php). Could I ask you to once again remove the file and do a full refresh on your browser to load the new CSS.
Sorry account was disabled :( I've enabled it now.
I also tried adding the Custom CSS Code you just advised, but this did not fix the issue.
For your information, I have also recreated the pagination.php in /templates/j51_calibra/html/
We were unable to access your site with the details provided with the following error...
As a solution could you try adding the following to the Custom CSS field of your templates parameters...
.pagination li {
background: none repeat scroll 0 0 #EEEEEE;
border: 1px solid #999999;
border-radius: 5px;
display: inline-block;
overflow: hidden;
padding: 5px 15px;
.pagination li a {
color: #555555;
.pagination li span {
color: #777777;
Email sent. Let me know if you need more information.
I've now deleted the pagination.php from /templates/j51_calibra/html/. This changed the looks, but did not fix the issue.
As a test I tried to change the templat to Beez3 and when I use Beez3 everything looks fine. See screenshots.
Is the default pagination.php located in /libraries/cms/pagination?
2. Could you try deleting the templates pagination.php so the default Joomla pagination.php is loaded. You will find this located at ../templates/j51_calibra/html/pagination.php from the root of your Joomla installation.
1. Fixed, thanks a lot!
2. It is the specific text "More Articles..." That has disappeared from my website along with the number "1, 2, 3" in front of the three article titles. Check out the two screenshots I've added, "Flere artikler..." is the translation of "More articles...".
For your information the #Links on my home menu is set to 3 and the three link titles are there. Only the numbers and intro text "More Articles..." is missing,
1. To amend this issue could you try adding the following to the Custom CSS field of your templates parameters where #CFCFCF is your responsive side column color...
#sidecol_a, #sidecol_b {
background-color: #CFCFCF !important;
2. Presuming I understand you correctly try editing the #Links field of your home menu items parameters to anything but 0.
