Any CSS you wish to add to your template you can add to the Custom CSS field of your templates parameters (Extensions -> Template Manager -> J51_Bordeaux -> Custom CSS). You can then add the HTML mark-up directly in to your articles, for which I would suggest using the CodeMirror Joomla Editor.
