1. samuel.fuchser
  3. Monday, 15 August 2016
Hi there
I'm using the Beaumont template. In order to change the responsive order im using the custom css code:
#main {
display: flex;
flex-direction: column;
.sidecol_a, .sidecol_b {
order: 1;
That works fine, except in the browser Safari.
Can you help me with this issue?
My example is: http://www.dachsubstrate.ch/index.php/kontakt
In resolution 767px width the layout changes to the new order.
Many thanks for any help :-)
Hi Samuel
What version of Safari are you using? Note to to reorder your modules effectively your browser has to support FlexBox which is not supported by some older browser versions.
It is a Windows Safari Version 5.1.4.
I have no idea what would be the actual one. I'm not a Mac person ;-) I just need to check all the browsers for the website I create because it's for a customer.
If you have a newer Safari Version, can you let me know if the conctact form moves underneath the address information on a smaller screen in the link I posted? That would be awesome :-)
Many thanks!
Hi Samuel
Unfortunately Safari for widows was discontinued in 2011 and at that point did not support FlexBox. Checking your site on the latest version of Safari (9.1), your custom CSS is working without issue.
Wow, perfect.
Many thanks!!
