1. sravoianu
  3. Sunday, 10 February 2013
Hi!
I reasently got J51 Arkadia. Instalation went perfect on J2.5 on a test server. Banner works perfect. no problem with menues.
I tried to install the kunena forums ... instalation went perfect . ( it seems you guys are using the same forum module - i might be wrong)
The problem i have is that arkadia somehow modifies the topic, category and post titles with a huuuge font. I can change the font style by changing the "Article head font" but no luck with the size.
When i chance the website template assignement from arkadia to the one that comes with joomla there is no problem with the forums - but no arkadia template ...
I haven't found an option to set the font size manually so it must be something in the css. I didn't want to start poking around before asking you guys.
[img]https://plus.google.com/u/0/photos/117835878337904103648/albums/5805936501185632865/5843384065621141666[/img]
EDIT . ok i am exploring the kunena CSS ... and i managed to identify some of the parameters ... 3379 line long :blink: I am putting comments in place for each variable .... so if anyone has the same problem all be happy to share ce css file
Hi Sorin
You could try defining the font size to this element of your forum in the Custom CSS field of your templates parameters (Extensions -> Template Manager -> J51_Arkadia -> Custom CSS)..
[code type=css]#Kunena span.kmsgtitle, #Kunena span.kmsgtitle-new {font-size: 16px;}[/code]
Where 16px is your font size.
Failing that would you have a URL to an example of this issue?
Thanks for the fast reply, apperently that solves only part of the problem ... only the post title itself ... post number , category name , time since last post ... same problem. In the kunena css the font size is in "em" units ... could this be the problem ?
ArcheAge Balcora
Try editing the following in your templates nexus.css (../templates/j51_arkadia/css/nexus.css - LINE34)..
[code type=css]h2 {
font-size: 32px !important;
font-weight: normal;
line-height: 100%;
text-transform: uppercase;
}[/code]
Removing the !important which i believe is causing this issue..
[code type=css]h2 {
font-size: 32px;
line-height: 100%;
}[/code]
Thanks !!!! :woohoo:
It works like a charm.
You are a master ... I couldn't identify the problem in a milion years !
