Message
OSM_INVALID_MEMBERSHIP_PLAN
  1. Internetional
  2. Pre-Sales Question
  3. Monday, 02 November 2015
I'm new to joomla and interested in the Template Arkadia.
Can I add modules etc. from the Joomla site to your template or just use the once that come with it?
Can I add own code for example to display TSviewer on my Homepage?
Thanks and regards,
Internetional
1. Yes. Any Joomla module can be added to the module positions available within the template.
2. Yes. Code can be added to Joomlas 'Custom HTML' module (Extensions -> Modules -> New -> Custom HTML). I would suggest using Joomla 'CodeMiiror' editor when working with code. You can create a 'Custom HTML' module regardless of the template you are using. There also appears to be some TeamSpeak extensions available for Joomla.. eg. http://extensions.joomla.org/extension/teamspeak-3-web-viewer
