1. FMG2007
  3. Tuesday, 08 October 2013
The mouse looses focus on 3rd level sub menu items. I go over the main menu item then I go to the 2nd submenu item and when I slide right over the third it looses focus and I cannot reach the 3rd level sub item. Can we do something about it?
Thx
Unfortunately this is in a local machine. I can send you a video instead.
I cannot attach a video file here. Give me an email instead.
Thx
I suspect the moomenu dropdown script is not loading. Have you added 'moomenu' Menu Tag ID field of your menu modules parameters?
Solved! I forgot to add "moomenu" ID in the module menu parameters.
thank you very much,
