Firstly add an image to each of your articles using the Images and Links tab of each article. Creating a menu item to your blog by navigating to Menus -> [YourMenu] -> New -> . From the Menu Item Type option select Articles -> Category Blog. Most of the options here can be left as the default. In the Blog Layout tab, set Leading Articles to 0, Intro Articles to 4 and Columns to 1. Click save and that should be it.
Thank you for your answer! But I already did that before. What I am missing is the styling with the Text floating into the picture. There must be a custom css somewhere.
I have the same problem.
But if I set the image float property of the article image to None, the heading disappears.
Is there any other alternative? I need the caption under each image and it is currently hidden.
