1. Aray
  4. Tuesday, 18 February 2025
I just notice that suddenly the posts Imprint and GDPR are not called up via the Footer menu.
Did anyone have a clue why?
  1. https://nido-mg.de
simplest solution. The posts are deactivated for whatever reason?
Have you created another menu entry in the top menu and tested whether it works there?
Can you link the posts somewhere to see if they work?
Hi Eumel7,
The posts were not disabled (see screen). I also created a new OnePage menu entry "Imprint" and the new Footer menu entries. The imprint and the GDPR can still not be accessed?
Faith here Ciaran would have to look?
Attachments (3)
Just to confirm that this is a template related issue, could you try enabling one of the default Joomla templates (Cassiopeia) and see if the issue still exists?
the changeover to Cassiopeia brought that there the entries are not shown.
I believe it's related to the last Joomla4 update, and the Ensley tempate didn't adjust to that?
It could be a broken link or a recent update affecting the footer menu. Try clearing the cache or checking if the pages still exist. Also, verify the menu settings to ensure the links are correctly assigned
Thank you for your answer, Jack.
The menu links, also in the footer menu had worked before the Joomla update. I deleted the cache without result. Using the screenshots, you can see that the posts/links are correctly assigned.
I believe that the Ensley template is not set to the Joomla update.
Or does anyone else have a solution note?
Attachments (3)
the difference is:
https://nido-mg.de/index.php/impressum works
https://nido-mg.de/impressum doesn't
check your link (options/link type/page display)
Hi Franc, thank you for your answer.
Unfortunately, I need a more specific reference.
Can you show me the place with a screenshot?
what are your SEO option set in global config?
Hi Franc, that was the solution. It was set to "yes" to use URL rewrite!
Thank you for your support :)
