1. ntsnet
  4. Sunday, 10 October 2021
I have a menu in a module in sidecol-1a. It works fine, but there is a small orange button under the menu title and I can't see where to remove it. It appears to be a nav-menu-button but the option to remove doesn't seem to be anywhere I have looked!
The attachment shows the problem.
Thanks,
Paul W
OK, if anyone else found this problem, I finally found the solution -
In the menu module advanced section you need to change the type from 'collapsible default menu' to 'default'. That remove the 'blob'!
