1. ntsnet
  4. Wednesday, 06 October 2021
Sorry too be back with another possible issue, but when trying to load one of the preset styles, it isn't changing. The default colours are retained every time.
I know I can change most things from the options, but it would be nice to load a preset!
Paul
Ah, should have updated sooner...
This was not a J51 problem, but results from brain fade - working too long on something (and too late).
Problem sorted.... ;)
Paul
Hi Paul
Is this still an issue for you? We have tested locally on a number of environments and unfortunately have been unable to replicate this issue. Once we select a preset from the dropdown and then click the Load Preset text, the preset values are always loaded into the fields without issue.
