1. Timer
  3. Thursday, 30 March 2023
Hi Ciaran!
Is it possible to add a Module-Top4/position to the "Colette" template? I am creating a custom built "one pager" page and I have hidden the content / sidecol positions, but I need an extra row in one of the Top / Bottom / Base module positions. Thanks for your reply!
Do you know that you can stack more than one module into one module position. Certainly easier than adding a module position.
Rolf
As an option this is not available however I guess you can create the positions manually. Note that these changes will be lost if you ever update your template. I havent tested the following so try at your own risk :)
Add the following to line 161 of your templates index.php...
<?php if (j51BlockExists($this, 'bottom-4')) { ?>
<div id="container_bottom3_modules" class="jarallax" style="background-position: 50% 0">
<?php if($particle_block == "bottom4") {echo $particles;} ?>
<div class="wrapper960">
<?php j51Block($this, 'bottom-4'); ?>
</div>
</div>
<?php }?>
And replace your templateDetails.xml with the attached (unzip).
Hello Ciaran!
Thank you for your help! It works perfectly! ;) You saved my weekend! Thank you so much!;)
Yes, I know, but in this case a separate module slot would be needed for design reasons (different background colour).
