1. mcardenas
  3. Thursday, 30 May 2013
I having an issue with the Avenue template. I do not know what it but two inner pages are having a problem displaying the entire page, which are boarding and contact us ( issue1_a.jpg and issue1_b.jpg). I changed the width of the full_content on the template CSS for it to be 100% and it fix the error, but it looks really bad on the iPhone (iphone1.png and iphone2.pgn. As you can see on the screenshots, the width of the content is smaller as if there is a invisible module on those areas, but I checked and there is not an additional module there.
Moreover, the template is having a gab on the bottom of the contact form when it is view on Google Chrome.
At the moment I can't provide you with the URL because it is offline, but if you need the URL and password to access the site, then let me know to what email I can send it.
Thanks you for you help.
Sincerely
Mibsam
Please, email me. I was not able to send you the screenshots because it would not allow me to do so. I can sent you the URL and access to the backend as well.
We hope to have now amended this issue by adding the following just before the </head> tag of your templates index.php (../templates/j51_avenue/index.php)..
<meta name="viewport" content="width=960px, initial-scale=1, maximum-scale=1">
Thanks for your help, but I was not able to fix the error with the code provided. I copied and pasted the code provided although it was already there, and I deleted the one that was there. Any other suggestion?
Thanks for your help. I did as you suggested.
"...To ensure your Joomla installation is loading the latest com_content could I ask you to rename the templates com_content folder (../templates/j51_avenue/html/com_content) to com_contentbu"
Not sure if this will help anyone else, but I pasted the solution here.
Thanks again for the good support!
