1. cedrea
  4. Tuesday, 20 April 2021
As Oliver I have a issue with the module extension j51_rotate.
the items are not side-by-side as in your demo.
They are all displayed in vertical mode, even if the horizontal mode is selected.
I send you the capture of the options selected.
What do I do wrong?
Thanks in advance
Cedrea
Attachments (3)
Hi Cedrea
I think the same problem as I mentioned in the other thread from me https://www.joomla51.com/forum/bianca-pagination-not-working-with-newest-mod-j51news-version
The module tries to use rotate.css and tiny-slider.min.js which aren't there in the correct folders. As temp workaround copy rotate.css into /media/j51_assets/css/ and tiny-slider.min.js into /media/j51_assets/js/ and test again.
This issue should be now resolved. There was indeed an issue with the Rotate module where a tiny slider option was been defined as an integer rather than a string. There was also an issue with your Gutter Size value which is best kept to below the width of your viewport.
Thanks a lot for your help!
Cedrea
